[The Lamuki's Belch. Reports, logs, assistance]Tube Screamer clone w/mods [in pr
Started by EARNEST, September 03, 2009, 02:42:08 PM
spaceace76
here's what i mean:
http://www.staples.com/Staples-Sticker-Paper/product_490429?storeId=10001&jspStoreDir=Staples&cmSearchKeyword=sticker+paper&fromUrl=home&langId=-1&catalogId=10051&cmArea=SEARCH&ddkey=StaplesSearch
basically peel off the sticker (or use it for something!) and use the glossy/waxy side of the backing paper (the non-adhesive paper, what the sticker paper is attatched to) for your transfers. this stuff is fairly cheap, and any office supply store should have some. the thinking behind this is that it's made for something adhesive to come off of it, so it will readily release the ink for transfer.
you can clean off the rosin, do a search here and maybe even google. i'm betting all you need is rubbing alcohol, or some other easy to find chemical.
is the tip removable? tips don't last forever, so hopefully you can find a replacement in a suitable size. the larger tip isn't bad, but as you've experienced it lacks some of the control necessary for finer soldering jobs. either way, you did a good job here, perhaps a little thick in spots, but with your iron i wouldn't expect anything different.
and experience will come! you're getting there, don't worry for a second.
EARNEST
Going to order a drill stand (Dremel Workstation), more info & details are coming soon
Dean Razorback V255 w/EMG 81/85 @18V -> Bugera 6262-212
DIY projects:
TS clone, in progress http://www.diystompboxes.com/smfforum/index.php?topic=78871.0
EARNEST
The project is on hold for a week or so. Need to order some tools + no time and no space, since I am moving in to another house.
DIY projects:
spaceace76
good luck with the move! take your time on the build, it'll be waiting when you're ready.
EARNEST
I have ordered some more tools and components. As soon as I get them and I'll find some spare time, I will upload the thread :) Also, need to buy some new soldering station, however i am too broke :( Damn it
DIY projects:
EARNEST
Extra components and tools are bought. Time for my new soldering unit...
DIY projects:
EARNEST
The project is NOT dead, just NO f**** time :) As soon as I am done with my exams and get, hope so, a new soldering unit, I will continue
DIY projects:
spaceace76
EARNEST
DIY projects:
EARNEST
Ok, a very long break, lots of studying and some financial difficulties. Finally I've bought a station I wanted.
Some pics:
http://img13.imageshack.us/gal.php?g=30072010.jpg
I am working, so as soon as I get some off time, I will continue :)
DIY projects:
EARNEST
Had to resolder all board, forgot everything, and found some tracks damaged, i will need to re-etch
DIY projects:
