350K pot ?
Started by danielzink, September 10, 2009, 08:36:20 AM
danielzink
Hey all,
I should probably know this...but I'm stumped.....
I'm working on a rehouse for a fellow and the pedal has a B350K pc mount pot in it...and I need a 16mm panel mount.
The existing pot is marked B354
Can I fab up a 350K out of something else ?
Thanks !
Dan
_________________
Naz Nomad
Strap a 1M resistor across a 500k pot will get you close (about 333k)
... or an A350k (log though) pot with a tap (which you can ignore) halfway down this link
... riding a Lissajous curve to oblivion.
jacobyjd
What's the application for the pot? The value may not be crucial :)
rousejeremy
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
  "B" could mean linear taper.
 Depending on the assignment of the original pot, a 250k or 500k might be fine, fairly likely.
kurtlives
If it's a linear pot (which is most likely is "B") then get a 500K(B) pot and strap a 1.2M resistor across the outer lugs. Would be pretty easy to mount the resistor underneath the PCB.
My DIY site:
www.pdfelectronics.com
Paul Marossy
Michael Weidenauer
Maybe you got some 500K guitar pots, measure their real value; in my experience most of them have lower resistance than they should have, some measure only 300k.
B is linear with most American and Japanese pots and linear with most European makes.
If the old pot is not completely wrecked, you can set it halfway and measure if it's lin or log.
Paul Marossy
In any case, you could easily approximate a 350K linear pot using a 500K linear pot and with a couple of 510K resistors in parallel with it.
zombiwoof
Weber Speakers sells a tapped 350k audio pot, if that would work.  It's about $2.  You wouldn't need to use the tap, but it is audio.
Al
bumblebee
Fender sell CTS 375k pots, not sure of the taper.
Paul Marossy
Quote from: bumblebee on September 19, 2009, 07:09:13 AM
That's an odd value.
