Jurgen Haible's Son of Stormtide flanger demo!
Started by StephenGiles, September 11, 2009, 04:44:37 PM
StephenGiles
Nitefly182
Sounds sweet. I bet you could pull it off as a stompbox but I have had really bad luck jamming designs meant for modular synths into pedals. The power supplies always caused so much noise and ticking. Any idea if this can be powered with more typical stompbox supplies?
oldschoolanalog
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
StephenGiles
Quote from: Nitefly182 on September 11, 2009, 04:58:26 PM
I should think that it's far better as a rackmount unit with the proper power supplies.
StephenGiles
StephenGiles
Bugger, I can't print them out - my black ink has run out!
Strategy
Quote from: StephenGiles on September 11, 2009, 05:34:43 PM
JH's projects are primarily designed as standalone units, but with e-z modular synth implementation. Also the majority of them have power supply sections on the board so you just need the wall wart and to populate those sections (you omit them for mod synth implementation)
He seems to like the rackmount setup. They are not huge though, it's feature heavy but you can fit them in a larger pedal enclosure. I'm doing his Tau Pipe Phaser, with full in/out and panel controls and CV stuff, but as a pedal. It'll be big and require a wall wart, but fine as a pedal. I've taken a break on it temporarily, but I'll post a build report when it's done.
Strategy
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
StephenGiles
#7
I cannot understand the obsession with tiny boxes :-\ I'm sure that a shining rack will impress the girls :icon_lol:
You do realise that it does TZF and bounce!
oldschoolanalog
Quote from: StephenGiles on September 13, 2009, 07:12:10 AM
I also don't understand why you would want all that processing power on the floor where you can't get to it easily for "on the fly" adjustments.
StephenGiles
It really needs to be at eye level for quick adjustments - but I'm forgetting, the more tiny boxes on the floor the faster one can play :icon_biggrin:
oldschoolanalog
Nitefly182
Quote from: oldschoolanalog on September 13, 2009, 11:16:19 AM
Id rather be able to just kneel down to my board right at the front of the stage than have to walk back to a rack and do a change there. Plus I can build a pedal and put it on my board. If I build a rack unit I then have to spend money on a rack to put it in.
StephenGiles
http://www.jhaible.de/sonofstormtide/sost_flanger_drums.mp3
Another sound sample, this time with electronic drums - listen to the pedal steel guitar effect about 3 min 50 sec in. I could see a lot of interesting sounds here from guitar.
