Noise and Mosfet
Started by kristoffereide, September 15, 2009, 10:35:40 AM
kristoffereide
All builds I've made with mosfets have the same high pitch noise. I'm using bs170's and it's the same noise whatever I build, be it the sho or theROG EA-tremolo. The effects are working like they should, so I don't think they are the wrong way. Any thoughts? Should I order a new batch, or add a DC-filter, or just give up using mosfets???
Quote from: biggy boy on April 12, 2009, 06:22:33 PM
I find it funny how I can have close to 1000 components, yet I never seem to have enough parts to make a project. :icon_eek:
DDD
MOSFETs are noisy by themselves. JFETs like 2SK170BL are low-noise, and you may try them to surprise yourself.  :)
kristoffereide
Yes, however Jfets arent the same as Mosfets
Cliff Schecht
The relatively high noise of a MOSFET a "defect" of the MOSFET design. 1/f noise is the most dominant force in a MOSFET under typical linear biasing conditions, but there is also Johnson (thermal) noise from the typically large gate resistors as well as other noise sources. You aren't going to get away from the 1/f noise unless you choose a quieter part or switch technologies completely i.e. JFET's (rebiasing may be required).
The lowest noise JFET that I know of is the U310. I think the noise spec is down in the 1 dB range (1 kHz at about 15 mA quiescent drain current). It's also got a relatively remote pinchoff voltage (2.5 V) and makes a great candidate for a low noise, high gain preamp.
anchovie
Do you get the high-pitched noise even when using a battery?
Cliff Schecht
Yes, the noise is inherent in the device. But 1/F noise is usually stronger at lower frequencies and so the high-pitch whine may not be what you think it is. There are a lot of other culprits that can introduce noise including bad grounding (weak grounds and star grounds), bad solder joints, misbuilds, etc...
Joe
P-channel MOSFETs are less noisy. I did the Obsidian this way and it worked out much better:
http://www.diystompboxes.com/analogalchemy/sch/obsidian.html
