Help with alternative diodes and transistors
Started by peps1, September 18, 2009, 06:13:13 PM
peps1
my wonderful shop for parts dose not stock 1914 diodes or 2N5088 Transistors........needed to build the Big Muff green Russian im trying to make from tonepad.com, anything eels i can use and still keep it reasonable authentic?
this is the shop i use http://www.bitsbox.co.uk/transistors.html so what have they got i can use :)
Quote from: peps1 on September 18, 2009, 06:13:13 PM
First of all, Electro Harmonix is (in)famous for using whatever they could get at surplus sales to build pedals, so building it out of whatever you can get *is* authentic!
Second, NPN transistors vary - a lot! - so in many cases, one NPN signal transistor is within the normal range of variation of another type.
The bottom line is - "keep it reasonable authentic" is not a huge consideration.  :icon_biggrin:
Out of that list from bitsbox, the BC548B or BC548C would be dandy. You **must** take the actual pinout into account when building, or you'll be back here telling us your build doesn't work.  :icon_biggrin: BC109 would too. Same comment.
The 1N4148, which bitsbox does stock, is almost identical to the 1N914. Use those.
ItZaLLgOOd
Lifes to short for cheap beer
peps1
Quote from: R.G. on September 18, 2009, 06:24:56 PM
;D that makes me feel better!  ;D
Thank you, have grabbed some of the BC548B and 1N4148......but, when you say You **must** take the actual pinout into account when building, what do you mean?
Quote from: ItZaLLgOOd on September 18, 2009, 06:27:01 PM
http://www.diystompboxes.com/smfforum/index.php?topic=56693.0
These guys were liking the 2n3904's.
Thanks for the link, grabbed a few 2n3904's too, will breadboard up and see what wors best for me :)
