Submini 6112 preamp preliminary build report
Started by bancika, October 04, 2009, 06:32:52 PM
bancika
Those miniature boards I posted before (http://www.diystompboxes.com/smfforum/index.php?topic=78925) finally got their home. I got some time to finish the preamp and fire it up this weekend.
I started off with dual channel 6021 based preamp schematic posted by Jeroen on this forum.
To be able to play with higher voltages I built a proper power supply with back-to-back transformer config. I used 12VAC 800mA wall wart and a 110:12V radio shack transformer as step-up.
With 6021 tubes it sounded very very clean. It's like having clean and "slightly pushed" channels, so I swapped both tubes for 6112. Now I'm getting nice crunch on the second channel. Still have to play with resistor values to tweak it to my liking. I think I'll bias the first two stages hotter, it's awkward to have the first stage biased cold. I'll try to bias the third stage colder to clip harder.
Luckily I used those submini tube sockets so I'm able to play with different tubes. On the other hand they are a b*tch to work with, it's not easy to stick 8 very flexible pins in at the same time. It took some practice and nerves to install the tubes.
I wasn't going to go over 80V B+ so I used 63V caps for plate caps. What I noticed is that it sounded better with higher voltages so I'll probably use higher rating caps there and increase B+ to 100-120V (this PS provides up to 130VDC).
For heaters I used heavily filtered and regulated 12.6VDC and wired heaters in series. To get 12.6V I strapped a diode from middle pin of 7812 regulator to ground. Filter caps are 2200uF. I still need to wire LED, prolly gonna use bicolor red-green for two channels.
When I'm happy with the results I'll draw a schematic and post it.
Unfortunately I didn't have my camera while populating boards so I don't have pics of the process.
I'll post updates...
Cheers,
Bane
Skruffyhound
Yeah, very nice! As it happens I've got a nice big batch of 6112 arriving sometime this week.............wondering what to do with them!
Brymus
bancika
tnx guys, here's another one. I'll try to take some better pics next weekend.
Ripthorn
Looking good.  I did a preamp based on the same schem, but with a mix of 6111 and 6021.  My B+ is 105V currently (looking to get it to ~150V).  I get up to a very nice classic high-ish gain sound. I added an extra, switchable gain stage as a boost and it gets all kinds of gain.  I look forward to clips, as I have a pair of 6112's just waiting to be used in something (though I am thinking TW Express preamp with switchable parallel 1st gain stage).
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
bancika
that's interesting. Maybe additional gain stage helps, but with 6021 I couldn't get it past very mild overdrive. I double and triple checked component values and nothing...with 6111 it would probably be even cleaner, since it has even less gain. I should have added a space for additional stage, I have some 5744 tubes which are single triode with 70 mu...
Cheers,
Bane
Skruffyhound
Ooops, now I've got a batch of 6112's incoming. Damn that Ebay.
