Force sensitive resistive pad - good for a wah-wah maybe?
Started by frequencycentral, October 06, 2009, 01:23:00 PM
I just spotted this via a thread on electro-music.com:
"This is a force sensitive resistor with a square, 1.75x1.5", sensing area. This FSR will vary its resistance depending on how much pressure is being applied to the sensing area. The harder the force, the lower the resistance. When no pressure is being applied to the FSR its resistance will be larger than 1MΩ. This FSR can sense applied force anywhere in the range of 100g-10kg."
Strikes me it might make for an interesting wah experiment?
Here's the link: http://www.sparkfun.com/commerce/product_info.php?products_id=9376
Here's the electro-music.com thread, with a very simple suggested interface circuit: http://electro-music.com/forum/viewtopic.php?t=37239
wavley
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
wavley
And people wonder why I have a meal of Beer and Chili before a gig.  Though it makes recording in a basement suck as we found out a few weeks ago when 2/3 of the band judged a chili cook off :icon_eek:
Top Top
This was a long time ago that I saw this, so I could be mis-remembering something, but I thought I remember seeing something about using the type of foam that IC's are shipped in (or something similar) to make variable resistor pressure sensitive pads.
Edit:
I knew I wasn't crazy. Here is an example of what I was thinking of... http://www.instructables.com/id/DIY-Force-Sensitive-Resistor-FSR/
Skruffyhound
I read that too Top Top, I believe it was an R.G. suggestion for achieving a variable resistance pressure pad, the downside being that the foam gets squished fairly quickly and has to be replaced.
Skruffyhound
So maybe R.G. reads instructables..... or their authors read his comments
Good links in this thread though
Ripthorn
You could use one for a burst box.  When you tap it hard, you get  a burst.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
puretube
FSR and other 3-letter words don`t get caught by the search-function...  :icon_rolleyes:
Quote from: puretube on October 06, 2009, 06:04:35 PM
Q: Parts list? Vero layout?
A: DIY?
  I didn't read about reliable much, but the sheets talked consistancy and actuator accuracy quite a bit.
 Looks perfect for knowing the exact pressure to Burst Box.
 And would certainly make a wha wah, whether the taper comes out right is interesting prospect for this device, quite a few application notes and guides to different functions some are certainly interesting.
puretube
puretube
Quote from: puretube on October 06, 2009, 06:30:45 PM
Quote from: frequencycentral on October 06, 2009, 06:28:51 PM
Quote from: puretube on October 06, 2009, 06:24:09 PM
link`d
Great link, thanks Ton! I still want to try it though.......
ya`ain`t got "Analoguru`s" schemo?
Quote from: puretube on August 13, 2009, 05:59:34 PM
Quote from: kurtlives on August 13, 2009, 05:20:35 PM
I wonder if you will show us a schematic...
:icon_rolleyes:
Why? haven`t you caught it from this so-called gentleman`s site yet ?:
http://analogguru.an.ohost.de/temp/EH_Tubezipper_factory.pdf
Quote from: puretube on August 13, 2009, 06:45:50 PM
Oooops.... an error occurred: above link isn`t the T-Z schemo, but
his offering of  his tube-E-Q drawing...
puretube
One problem you have to address with FSRs is pressure overload. They're good between 100g and 10kG; no problem there.
But we've had problems with people breaking off the activators of stomp switches and the shafts of pots by stomping on them; and I've seen more than one guitarist standing, single-footed on a wah pedal. For a reliable device, you need to ensure that the FSR is not damaged by pressures of 10kg up to maybe 100kg.
Top Top
Quote from: R.G. on October 06, 2009, 08:18:28 PM
For DIY and home use I could see them as fine, but yea, for other people to abuse... that's a different story.
Processaurus
Puretube, have you had any FSR's fail/get out of calibration in your pressure wah prototypes?
For a DIY thing, the easy way out would be to have a comparator driving an LED to show if it's overloading, it'd be up to the responsible adult to temper their enthusiasm...
