RG's Parametric EQ Article
Started by aziltz, October 17, 2009, 01:36:31 AM
aziltz
Has anyone worked through the math on this one?  http://www.geofex.com/article_folders/eqs/paramet.htm#variable_l
RG is saying that 0.15u for C1 and 0.02u for C2 will give you a range of 100Hz to 450Hz.
I'm off by 3 orders of magnitude.  I'm getting 100k-450k...  Just from calculating the gyrator inductance and then the center frequencies.
I'm trying to design a 5-Band Parametric EQ.  I know what frequencies I kinda want, and I'm trying to match it up with common capacitor values.
aziltz
NVM, I've figured it out.
Not all the equations for the center frequency on that page have the SQRT(LC) in them.  Some are label only LC and I was using that.
RG, you might want to quick-edit that at some point.
