A question for Paul Marossy- Solo Pro
Started by boogietube, October 17, 2009, 10:57:40 AM
boogietube
Is there a reason you chose to use 1 meg audio pots here?
I want to use this device for my acoustic guitar which has a 10k audio pot for the volume..
Did you make it this way because an electric guitar vol pot value?
Do you think it will work well with the 1 meg pots in my application, or should I use 10k ones instead?
The only reason I'm asking is because I have to order the pots and I'd like to get the right value.
Here's the link in case anyone else can answer:
http://diyguitarist.com/PDF_Files/SoloPro.pdf
Thanks,
Sean Harris
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
kurtlives
My guess is he chose 1M so the signal is not "loaded down". Higher input impedance.
My DIY site:
www.pdfelectronics.com
