Problem with audio probe
Started by TrentC, October 28, 2009, 04:12:31 PM
TrentC
I can't seem to get this audio probe to work. I think maybe I have the tip and sleeve confused because I bought a cheap horizontal jack. Are the contacts on this jack switched? like, the tip contact is the closest to the input? Thanks guys.
http://mouser.com/ProductDetail/Neutrik/NYS2122/?qs=jCymNF74TgX6W%252b9GcDP2KA%3d%3d
aron
Yes. The contacts are switched. Use your meter - plug in a 1/4" cord, then use your meter set to continuity to test which lug is active for the tip.
