Micro Amp at 18volts. Understanding the IC differences? Really wanna learn...
Started by sevenisthenumber, October 31, 2009, 01:02:08 PM
sevenisthenumber
I built a Micro Amp up and originally used a tlo71 as the ic. When i ran 18 volts it wouldnt work. I swapped the chip out for a lm741 and it works great at 9 or 18. Can someone teach me why this is?
CynicalMan
There shouldn't be a problem with running a TL071 at 18V. It is rated for +/- 18V supply voltage and if you are running it on 18V, you are only giving it half of that. Maybe yours is defective.
oldschoolanalog
Bad batch?
Where did you get the 071's from?
BTW, sevenisthenumber: You are officially a Timer IC with your 555th post :icon_mrgreen:
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
sevenisthenumber
Quote from: oldschoolanalog on November 01, 2009, 10:12:18 AM
Bad batch?
My life is complete!!!!  :D
