Any body have some fun way to use CA3080 ???
Started by solderman, November 05, 2009, 06:18:22 AM
solderman
I happened to have a couple of CA3080 that I don't know what to do with. I ordered 10 from Smallbear and used them to build two MXR Dyna Comp (one for a friend) and one Ross compressor so I don't need any more of those. Any suggestions??
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
bigchasbroon
i can trade you something for a couple, pt 2339 tl072 jrc4558 2n5088 2n3904 2n3906 or anything else you might need.
Mutron Micro V envelope filter, Maestro S&H.
...or...you could simply hang onto them and wait.  They might be worth something in a few years.
Ben N
#3
Small Stone-ish phaser; Anderton VPR.
Many simple schematics for electronic drums will use a 3080 in order to have some envelope-dynamics.
aziltz
could it be used to make an envelope triggered swell?  like the slow gear minus the audio gating, so that it passes signal if you don't pick hard enough to trigger the swell?
You can probably do that with the PAiA Gator circuit, which uses a 3080.
There are quite literally dozens of VCF designs using two 3080's. Oberheim SEM and EDP Wasp spring to mind - both of those are multimode too (ie HP, BP, LP).  8)
sean k
Tonepad has the Anderton volume pedal mod using a 3080 and it's always good to have a volume pedal without pot scratch noise.
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
solderman
Thanks all
There seems to be a lot of choices here ;D
www.soldersound.com
