My ultimate pedal board supply.
Started by WhenBoredomPeaks, November 08, 2009, 07:41:39 AM
WhenBoredomPeaks
Here's the plan:
I will buy one "bigass" supply, something like a 18V, 1000mA unit. It will be connected to the pedal's (the "power brick" i planning) input.
The box will have several outputs, like 6 pieces of 9V out, 2 pieces of 12V out, and one 18V out.
After the power enters the pedal, it will be filtered through a Beavis style power filter.
The plan is that i will use voltage regulators for creating different voltages, like 78L09s and 78L12s. Will they add noise to the signal? Will this work?
guitarman89
Use a filter+regulator+filter for each output. I have a similar power distribution system on my pedalboard, only a 12V input, 4x9V output and 1x12V output.
built: MXR Dist+,dod250-280,dr boogey,IC buffers,cmos drive,multiface,20W SS pwr amps,phase90,tubescreamer,rat,amzMB,wuly mammoth,dod280,zombie chorus
under constur:60W 3886 amp,jcm800 em
www.myspace.com/guitarmanbll
www.myspace.com/filospinatopunk
geertjacobs
If I would build the Ultimate PS it would involve this:
https://taweber.powweb.com/store/wpdlxfmr2sch.jpg
This way you have galvanically separated secondaries, which is always good to avoid ground loops, hum etc...
