4PDT relay - good deal spotted in Aus
Started by composition4, November 12, 2009, 10:58:56 PM
composition4
Hi,
Rockby (based in Melbourne, Aus) have 4PDT relays on special here this weekend, 10 for $10.  I have no affiliation with them BTW
http://rockby.com.au/catresults.cfm?stock_no=10729&imageField2.x=12&imageField2.y=7
they are double coil latching 5v relays.  Gold plated contacts, etc etc.  I bought about 60 of them last time - and they work REALLY well for true bypass on pedals or in a switching system. - all you need is the relay ($1), a hex inverter, a SPDT momentary switch and a couple of resistors, diodes and caps - total cost about $4, much cheaper than a 3PDT. And you get a whole extra pole.  Or if you would prefer not to muck about with logic ICs, you can use a SPDT switch instead and forget the inverter.
More messing around, but if you incorporate the switching inverters/components onto your PCB/vero/perf, it's no more hassle than soldering a few more components.
Another possibility it brings along is remote switching.  There's a lot on geofex about remote switching.  Anyway, let me know if you have any questions.
Jonathan
puretube
composition4
They seem to have the special on fairly often - I'll let you know when it's next on because I keep my eye on that site quite a bit.
Jonathan
puretube
composition4
