Ruby help! check my strip layout..
Started by had_hc, November 14, 2009, 01:33:10 AM
had_hc
based on erik hansen's marsha-ruby schematic, i built a marsha ruby on a strip board..
here's the schematic
and here's my stripboard layout
is it correct?
i've soldered everything up including the headphone out (using GGG's headphone mod wiring). everything seemed connected right.
the j201 (later changed to MPF102) are biased to 4.5V.
but i got oscillation sound coming out of it especially through the speaker. it's not high pitch, but some sort like a low freq oscillation (i think).
anybody got any idea what's wrong with it?
thanks in advance
do ask me for any more info if needed
had_hc
by the way, the stripboard layout i did based on a fetzer-ruby stripboard layout done by Bancika. i downloaded from diy-fever.com
punkin
Unless I'm missing something here...I see a jumper from your IC pin 3 going up to the volume control on your Vero board but the schematic shows that 3 only goes to ground.
Ernie Ball Music Man - JPM, THD Univalve, Grace Big Daddy, PepperShredder, BSIAB2, FireFly Amplifier.
had_hc
that strip line is for ground and volume 1 as per schematic goes to ground. am i rite?  by the way c4 in the layout should be 100uf. typo there.
KazooMan
Not sure about the oscillation, but is the gain control wired properly or does it work backwards?
CynicalMan
In the schematic and your layout, there isn't the necessary filter on the end. In the original ruby it's the 10Ω resistor and the 47nF cap.
Adding those in will probably fix the oscillation.
had_hc
Quote from: KazooMan on November 15, 2009, 01:30:34 PM
i used 5k gain control. i'll try rewiring the pot. maybe its backwards.
Quote from: CynicalMan on November 16, 2009, 04:42:44 PM
oh, i followed erik hansen's schem exactly, which he mod from fetzer-ruby schem (by ROG; can be found it ROG's FAQ). the schematic of fetzer-ruby also don't hav that filter.
but i'll try adding that if rewiring the gain pot doesn't solve my prob.
thanks!
