jb qwik
Started by pazuzu, November 16, 2009, 02:32:23 PM
pazuzu
just a heads up for anyone who hasn't tried this because they are stubborn like me:
after passing this stuff up for some time in lieu of the original formula i finally tried it, and it works really well. sets up in minutes and is cured in under an hour. really great, the only drawback is minimal work time.
Cliff Schecht
Is it not just a cyanoacrylate derivative of some sort?
gutsofgold
would this work to adhere those metal battery clips to the enclosure?
GP
If it's an epoxy (and i think it is - not available where i am) then, in general, the quicker setting the epoxy, the weaker the finished bond.
I use all sorts of different epoxies for diy and all have their uses and drawbacks
  if the surface to be 'welded' is flexible, expect only temporary or lucky results..I tried the kind made from a plate of springy material which forms a 'U' shape around the battery, it has a screw hole in the base, JBWeld didn't do the trick.
pazuzu
  Yupp, nasty stuff.
 We glued a crack [a frouning leak caused by ice blowout] in 350 chevy engine block with the a 24 hour type, that winter the seal withstood 20 below to operating temperature, amazing glue.
runmikeyrun
I fixed a large crack in a dirt bike expansion chamber with it once.  I expected it to burn right off, but it held tight!
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
