is there any simple (clean) Low Octave Analog???
Started by richon, November 18, 2009, 08:54:19 AM
richon
i've been searching, but the one thing i get is the BlueBox, which isn't clean (fuzz)
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
jacobyjd
Analog Octave down != simple OR clean.
There's really no way to make that happen. The only thing I could think of would be to use a blue box or slacktave and LPF the crap out of the octave down, then add a gain recovery stage to bring it back up to unity.
MarcoMike
what about stealing the OC down from circuits as the microsynthesizer, or Pearl OC3 (3?)... or ashdown suboctave.... this  last one is integrated in my amp and it is a very small and simple circuit board connected to the main pcb... I am sure there are schematics online, somewhere...
Only those who attempt the absurd will achieve the impossible.
There are two generic approaches to analog generation of an octave down.  One is the approach used by the Blue Box, which uses a flip-flop to generate a square wave triggered by rising and falling edges that exceed a threshold.  The flip-flop can only be in one or another state, with no in-betweens.  That's a square-wave output.  It can certainly be filtered to smooth it out, but it starts out life as a square wave.
The other approach also uses the flip-flop to derive the "pitch" of the note, but does use the flip-flop's output directly.  Instead it uses the flip-flop indirectly to "gate" the original signal at half the frequency.  In other words, lets say I had a 100hz sine wave.  If I omitted every other cycle and replaced it with silence, you would hear half as many peaks per second, which is a lower frequency.  By gating the original audio input, the content that gets heard starts out clean, and doesn't get too nastied-up by the gating.  People describe this as being "smoother".  The gating, however, still introduces its own artifacts, so it could not be described as absolutely clean.  Still, since the flip-flop output is a constant amplitude, using the flip-flop to gate the original signal tends to preserve more of the dynamics of the original, which people will perceive as being cleaner.
richon
excelent
and is there an example or circuit of the second way to reach the "one octave down"???
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Yes, the Korg, Boss OC-2, Pearl, and many others.
earthtonesaudio
I suspect you could make a clean octave down digitally with less circuitry than the OC-2.
aziltz
I think the Boss OC-2 was the cleanest example of Analog Octave Down.  It drives a flipflop with a 1/2 frequency signal and uses that to invert the polarity of the input signal.  Meaning, the octave down is created using the harmonic content of the guitar.
I think.
chicago_mike
