Best software for pedal enclosure layouts and design's
Started by Hupla, November 24, 2009, 08:20:14 AM
Hupla
Hey guys.
Does anyone know of a free software that is good to do this. Doesn't need to be too fancy.
Completed builds: BSIAB2
Pedals to build: Dr.Boogey, TS-808
Skruffyhound
Google "Sketch up" easy to learn at least to make drilling patterns, 3D takes a little longer, but still easier than other programs. Good Luck
Ibanezfoo
Inkscape, Gimp, Scribus, etc... these are all great open source applications.
aziltz
Quote from: Skruffyhound on November 24, 2009, 09:05:21 AM
i second this.  i use it weekly to make to-scale drawings with easily added dimension measurements.  great for drill patterns.
Hupla
Quote from: aziltz on November 24, 2009, 10:24:24 PM
Are you guys talking about the free 3d one?
Paul Marossy
Hupla
Say if i wanted to make a template for etching enclosures would google sketch up be good for that?
Ripthorn
I use a free AutoCAD workalike, A9CAD.  It works similar to AutoCAD (what I learned originally), but it doesn't have some of the nice tools.  But hey, it's free.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
Jarno
I'm a mechanical engineer, and I'm using Pro/Engineer at work (3d modeler). I've recently put all components in there and made a layout, so there's no headscratching when drilling each and every enclosure anymore.
Far from cheap! There was a free alternative at one time, I think it was called Pro Desktop Express, but I think they've pulled the plug on that one.
Does anyone know of a free alternative to Adobe Illustrator? (vector based graphics program)
Fender3D
Open Office Draw will allow you to do both drilling and designing ala CAD or Publisher
markeebee
I'm a mech eng too.
I've got a bunch of fancy software that I use at work but, frankly, I find the drawing tools in Word to be perfect for doing really quick and simple layouts.  It's by far the easiest to learn - you probably know all that you need to know already.
Inkscape is a very good freebie alternative to Illustrator, by the way.
Ripthorn
Ibanezfoo
Quote from: Jarno on November 25, 2009, 02:03:33 PMDoes anyone know of a free alternative to Adobe Illustrator? (vector based graphics program)
Inkscape:  http://www.inkscape.org/
If you use alternative OSs, theres these too:
Xara:  http://www.xaraxtreme.org/
Skencil:  http://www.skencil.org/
jessej
welcomb
I've just started to use SketchUp mainly to layout and squeeze all the components into tiny enclosures. There's a box template for our common Hammond enclosures online!
obblitt
How exactly do you draw a drilling template?
Is it as simple as drawing all the enclosure's sides that need to be drilled and drawing holes where it needs to be drilled and then implementing some kind of scale? I need to put 18 holes into a 1790 and I have NO idea where to start.
aziltz
Quote from: Hupla on November 25, 2009, 09:59:01 AM
yes. The free version rocks my socks off.
Hupla
Quote from: welcomb on November 25, 2009, 09:19:19 PM
Have ya got a link to the box template or are they already on it?
Jarno
It's on RG's Geofex site, BB's are a favourite of his, so the layout is just for this size, no B or A layouts.
Skruffyhound
Actually it should be possible to import the Hammond AutoCAD drawings to sketch up. We've imported some CAD files at work but I haven't tried this yet.
QuoteHow exactly do you draw a drilling template?
It's as simple as making a few calculations to divide the space up, so all knobs/switches/power jacks/jacks etc. are nicely placed aesthetically and functionally. You can do it with a pencil and a piece of paper,you only need to draw the face to be drilled and the center points of the holes you want, cut out the shape  and tape it to your enclosure.
     The difficult part is the 3D inside the box, imagining how everything will fit in. Will this perfboard go free of the jacks if I place it here etc.
As my builds get more complicated I think there's a tendency to try to build as tight as possible, it's not really necessary, but I can't help it. Thats where 3D technical drawings start to be required.
