Bsiab2 is too quiet
Started by bft450, November 25, 2009, 12:55:17 AM
bft450
I just finished building a bsiab2 with contour control. The pedal works great but is too quiet. There must be a problem because even when it is fully dimed out it is not as loud as the bypass tone. I have triple checked all my connections and I am stumped. :'(
bft450
I will do the full pinouts and voltages tomorrow, I was hoping this was common/simple.
ubersam
what is the "contour" control? maybe you are loosing too much signal through it? i just did a screamer with an AMZ bmp+presence control and there was a lot of loss through that. i had to convert the 2nd opamp to a recovery stage to recover the level.
darron
not that's it's much help, but i'll confirm that the bsiab2 has lots of room for boost, and should be way above bypass level with the vol pot maxed.
bft450
Well I was running through the pinout voltages and found a bad j201. All is good now, thanks ;D
