Ruby weird sound...
Started by Top Top, November 29, 2009, 06:06:21 AM
Top Top
I built a ruby. At first it was doing a weird tracking/oscillating thing (oscillation did not appear until you played a note, oscillation sort of followed the note you play like a poorly tracking octave effect). Then I tried replacing a couple components and bridged across a couple points accidentally with the power on.
When I got everything back in order, the oscillation was gone, but instead, it has very little output and sounds very fuzzy and weak.
I checked voltages against another ruby that I have that is working fine, and all the DC voltages are more or less the same at all points.
I didn't socket the transistor or 386, like an idiot. Where would you start? Transistor? 386?
