Reducing power output of an amp?
Started by dmm128, December 05, 2009, 07:16:38 PM
dmm128
I just built a ruby amp and was wondering if there is a way to reduce the power output.  I know Roland puts a power squeezer on there amps but I don't know how its done.  I am looking for the amp to break up at a lower volume.
raulgrell
With the ruby, perhaps it would be a better idea to add a (switchable?) distortion stage and a master volume control...
1 Reduce the power input, instead of 9vdc, try 7vdc supply.
2 Use a less effecient speaker [may sound different].
  Dropping the input voltage = lowers headroom = breaks up at lower volume.
GibsonGM
Essentially, Pete's talking about VVR for the Ruby, lol. Variable Voltage Regulator.  Just use an adjustable supply voltage, and as he says, off you go....they do this on larger amps as "power scaling"....
  LM317 Voltage Regulator.
  Beware the Radio Shack pin#/letter re-code and write the pinout under a drawing of the chip, then double check it.
