OT- Telephone as a vocal mic
Started by ianmgull, December 21, 2009, 02:57:15 AM
ianmgull
We've all heard the sound countless times, I want to convert an old handset for my singer. There are two wires coming out of the mic so it's not a balanced connection. I'm just trying to figure out how to terminate the connection. Would a buffer be helpful for this sort of thing? I plan on building a stompbox that when engaged buffers the mic, and when "bypassed" simply mutes the mic (when he uses the normal mic). Any suggestions?
candidate
Processaurus
If it is an electret mic like most telephones it needs a couple of volts of power to run an internal FET.
http://www.epanorama.net/circuits/microphone_powering.html
An opamp boost like the micro-amp would probably be fine, you might be able to get a little better noise performance if you precede it with a moderate, discrete gain stage.
Not sure what the ancient rotary type telephones use for a mic, or the preamplifier needs.  Those probably sound the most telephoney, modern electret mics are more mid-fi.  Of course you can always make them sound worse!
sean k
Might be an ol' carbon mic in which case its alike a piezo and wants to see a high impedance ( cause the style of mic sees a capacitance in parallel with the source so the roll-off of lows is built in with a normalish input impedance) to get the bass sounds but if you want telephoney and that vintage kinda intercom sound then unbuffer it and just join it to a 6mm plug and way you go.
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
mikemaddux
I just wired up the speaker to a 1/4 inch jack and it works great as a lofi mic or as a really really quiet speaker (like you have to hold the phone up to your ear to hear the volume)
very cool 1 hour project...
Completed Builds: A lot...
Boogdish
http://www.instructables.com/id/Telephone-Handset-Microphone/
and if you're not sure if it's going to sound good, go listen to some Japanther, they've used phones as mics every time I've ever seen them.
http://www.youtube.com/watch?v=YRfF7A1whvw
Carbon mikes are low impedance and floating.
They can be wired balanced; balanced lines were essential to telephone operation. No 3rd wire because they have no shield.
BUT carbon mikes require a source of power. And a lot more than an electret. And an interface to meld the DC power and the audio signal. This was traditionally done with a "repeat coil", a fancy name for a transformer. Resistor and capacitor is less efficient, but since you won't have 9,999 telephones in your district, efficiency is not too important.
At a glance, the Instructables link seems wrong. Impedances are way high. His thoughts about power are confused.
This seems right, to me, for classic telephone carbon mike to modern recording input.
As mikemaddux says, the earphone is sometimes a dynamic transducer which works as a mike just fine. However you don't get the carbon-grit.
ianmgull
Thanks for all the info guys, time to dig in...
Nitefly182
Quote from: ianmgull on December 22, 2009, 02:48:53 AM
You could also sacrifice a cheap microphone and install the passive element into a telephone handset for a simpler solution.
chi_boy
Could you use something like the Telephone / Noise pedal from R.G.?  It's on his site somewhere. It's designed for guitar, but maybe it could be adapted to mic use.
"Great minds discuss ideas, average minds discuss events, small minds discuss people." — Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
mikemaddux
Quote from: Nitefly182 on December 22, 2009, 03:21:45 AM
Thats exactly what I did...
ianmgull
Quote from: mikemaddux on December 22, 2009, 09:39:54 PM
Did it sound as muffled as you would expect from a telephone? I thought about RG's lofi pedal but part of the appeal of this is that it looks pretty awesome for your singer to shout into a telephone on stage.
doug deeper
japanther uses the speaker part of the phone as a mic.
mikemaddux
[/quote]
Yep, very muffled and lofi....it was great
birt
i've used both these setups for carbon mics:
i have one that is just the handset. the earpiece has been removed so there is some space for a 3V lithium battery there. on/off switch in the middle of the handset, cable with mono jack as output. i used the resistor/cap setup because a transformer would take too much space.
http://www.last.fm/user/birt/
visit http://www.effectsdatabase.com for info on (allmost) every effect in the world!
