Possibly very stupid question.
Started by john.hostetter, December 25, 2009, 12:52:56 AM
john.hostetter
So I just completed an "Improved Hum Free A/B/Y" and it works great! I'm so proud...
Two questions:
-I noticed that when I have a battery in, I cannot get the LEDS to turn off. I can turn one off, but at least one is always slowly draining my battery. Is this something I can solve by modifying the LED circuit? Do I need to put in an on/off switch?
-The circuit didn't work for me until I fooled around a little with the components. I noticed on the circuit board and in the bill of materials the project calls for a 2N3906 transistor. I didn't see this included in the schematic. Just out of curiosity, what does this component accomplish? Is it necessary?
Possibly very stupid question, but.... what plan did you use?
The one at http://www.geofex.com/FX_images/humfree2.gif shows a power switch. (Also two batteries.) The signal passes through the chip (triangles). When you turn it off no signal will get through. And interestingly the "off" LED still has battery-drain; he just diverts current from the LED (possibly to reduce click).
The version at http://www.geofex.com/FX_images/spltr2.gif is quite different, does not pass current around "off" LEDs, and says "power switching not shown".
And the "Hum Free Signal Splitter" shows a clever 3-transistor power switching scheme.
It's not a power-hungry box, but you do want to turn it off or remove the batteries when done playing.
You can build a no-battery A/B/Y switch. But there are real benefits to these buffer chips, and some convenience in the LEDs. What does it cost to run, maybe a dime an hour? That's less than your beverage cost.
