TonePad Rat debugging help
Started by neil411, January 14, 2010, 03:34:22 PM
neil411
Hi,
I need some help with my TonePad Rat (La Rata) build.
I get no sound other than a raspy noise when the strum really hard. Bypass works fine.
I used a audio test probe to trace the audio, I get audio into the IC, but nothing comes out the other side. I have swapped the chip with a new one - no change.
The only parts substitution I made was to use a 2N5457 in place of the 2N5458. I swapped that out for a J201. No change.
I have 9.45 volts going in to the circuit.
My voltages at the IC (an LM308N) are way off:
P1 - 8.89 v
P2 - 0.506 v
P3 - 47.4 mv
P4 - 0 v
P5 - 21 mv
P6 - 0.511 v
P7 - 9.43 v
P8 - 17.6 mv
Help!
  Test for ~1/2 volts of supply [about 4.5v] at the junction of the voltage divider resistors, they should be the same R value.
neil411
neil411
Thanks, I figured it out, I had the wrong value cap in the compensation cap for the IC.
