My planed Rocktave Divider mods
Started by alparent, January 15, 2010, 10:27:03 AM
alparent
I'm planing on building a Rocktave Divider but I'm thinking of not using any 4013 but using 3 4017 with a rotary switch and a level pot each.  I was also wondering if there was a way to add a level pot for the straight signal? (Would that be useful anyways?)
Dose turning down the Fuzz pot really gets rid of the fuzz and gives you a clean sound? If not, how could I do that?
Any expert opinions out there?
isildur100
Hi,
In my opinion, the shin-ei octave box sounds cleaner and better, and is easier to build.
Maybe you should give it a look, the schematic is lying around the net.
cheers
alparent
Thanks for the input John will check it out.
Just spent my lunch hour with Mark Hammer, I know, I know, I'm blessed!  :icon_redface:
I'm going with only one 4017 (like the article suggests) but I will add a pot to control the clean signal.
Thanks again Mark.
igor12
I recently breadboarded Rocktave, doing quite a bit of tweaking.
1)a way to add a level pot for the straight signal? (Would that be useful anyways?)
A. Add a 10k pot after c8. I think one side must got to 4.5v instead of ground. I think it is useful.
2) Dose turning down the Fuzz pot really gets rid of the fuzz and gives you a clean sound? If not, how could I do that?
NO, turning down the fuzz, turns down the fuzz of straight sound.  The octave down is still square (fuzzy).  The tone control will actually smooth it out a bit.
