ExpressPCB - Need Op Amp w/8 pads (741)
Started by Steve Mavronis, January 16, 2010, 12:15:29 AM
Steve Mavronis
I tried downloading several user made custom libraries but can't find a PCB representation of an 8 pin Op Amp that is 0.3" wide and 0.1" pin spacing on each side. I'm not sure how to draw a custom symbol for the Op Amp rectangle that would go in between the 8 pads. Is there anyone using ExpressPCB that has something I could use or explain how to create one?
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
John Lyons
You mean just a Dual op amp?
There are some in the expressPCB library.
They are .4 wide though as is standard.
Basic Audio Pedals
www.basicaudio.net/
Steve Mavronis
No not those little tiny ones. Like a LM741CN IC for example, which pin-wise on a 0.1" grid spacing would occupy a 4x3 grid spaces on the PCB, complete with the 8 pads with drill holes. If you also use DIY Layout Creator for comparison you see how an 8-pin IC chip looks on the PCB over 8 pads.
.Mike
Do you mean you want a square drawn around the outside of all the pads?
Save this to My Documents\ExpressPCB\PCBComponents_Custom
http://www.mediafire.com/?jj04yd2oizh
Open or restart ExpressPCB. Open up the Component Manager, click Custom Components, look for DIP-8 - standard.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
Hello,
Just open up the Component Manager and click on 'find' and then type in dip and you'll get sockets from 4pins on up with the spacing you want. If you want to modify the component (i make bigger pads and smaller holes for all my components), highlight it, open up the Components and click on Ungroup PCB Component. From there you can make any changes you want, don't forget to number any pads,  you then highlite all the parts of your customized component, open up Components again and click on "Group to make PCB component. Then save it to your custom library.
dave
Steve Mavronis
Quote from: .Mike on January 16, 2010, 01:13:39 AM
Do you mean you want a square drawn around the outside of all the pads? Save this to My Documents\ExpressPCB\PCBComponents_Custom
Thanks! Yeah the socket is nice too. Actually part of this is my bad. I mistakenly assumed the "DIP" items were DIP switches, LOL.
