2 circuits, 1 box, 1 circuit won't work unless I remove indicator led
Started by dr.benway, January 18, 2010, 08:48:56 AM
dr.benway
I have two independent circuits (separate inputs and outputs) in one enclosure. They're wired in parallel sharing the same power supply.
Each effect has a spst toggle with a led to indicate on/off.
There's a 4k7 resistor in series between the leds + and the power supply.
The problem is that only one led lights and only one effect powers up. If I remove the second led the second effect powers up normally.
Any idea where the problem is coming from?
I initially had a 4k7 resistor between each led and the power supply but that didn't work either.
GibsonGM
Can't really see what you've got going on, Benway, but here's what I think.  If your LEDs are in SERIES with the power supply, they're going to act like switches of a sort.  Are they in parallel, across the power supply (to ground) and switched??  Are they supposed to be true bypass, and run in parallel?  A drawing would help to see what's up.
~Mike
dr.benway
here's a quick pic hope it's ok.
The leds feed into the 9v+ in of each circuit.
Could it be a grounding problem ?
I'm learning on the fly so my answers might not be helpful.
jacobyjd
yeah...you're going to want to use that switch to go between +9v and GND, not +9v on your circuit. The LEDs (and the resistors) are limiting your power. This is why we use 3pdts to bypass effects--2 poles for true bypass, and 1 pole to connect the LED to GND from +9v. You then run separate lines directly from the +9v input to your boards.
dr.benway
ok so I go between 9v and ground but can I run a wire from the 9v lug on the switch to the circuit ?
or do I have to use 3pdt switches if I want the leds ?
jacobyjd
That's not good practice for several reasons--
1. essentially, you're cutting power every time you hit the switch. You want power to be constant.
2. You're still using a pole of the switch, so you're not going to have true bypass (which is ok, as long as you have a good buffered bypass setup, but that doesn't appear to be the case).
So--your solutions are as follows:
1. Get a 3pdt switch and call it a day
2. Build a milennium bypass on a daughter board (uses a few extra components to still true-bypass the effect, but also switch the LED with a DPDT switch)
Make sense? :)
dr.benway
boogietube
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
