7 segment LED displays - top mounting?
Started by kissack101, January 27, 2010, 02:16:29 AM
kissack101
Hey,
I've been looking to include a 7-segment LED into a pedal I'm building. Ideally I'd like one that I can mount 'on the top' of my enclosure, i.e. I can drop it into a hole and screw it down, all I've been able to find are ones that I need to mount to a PCB and mount to the enclosure 'from behind'.
Does anyone know if/where I can get a 'top mounting' LED display? Any help would be gratefully received!
Thanks,
Adam.
kissack101
Processaurus
"Panel mount" is the term you're looking for.
JKowalski
Put it on a seperate piece of PCB with a flat multi conductor cable to hold all the pins coming from the PCB, drill mounting holes on the PCB, and screw it onto the enclosure. You can put a header on your PCB to plug the multiconductor cable into, to make it all nice and neat.
__..._______________...__   - Enclosure top
   ||   !!7SEGMENT!!    ||
__||__!LEDDISPLAY!__||_    -PCB
G. Hoffman
I've actually designed myself a little 7-segment display board that contains the display, the decoder IC, and all the current limiting resistors.  It is a modular thing, and all I need to send it are power, ground, and BCD code.  It ends up saving a few off board connections, and when I'm making up a schematic I can just draw a connector for the display.  It's about .2" taller, and about twice as wide as the display itself.  (It could probably be made smaller if you really worked it, but I didn't see the need.)
Gabriel
JKowalski
Quote from: G. Hoffman on January 30, 2010, 04:34:41 PM
Gabriel
Hey, would you mind sharing your layout for that board?  :icon_biggrin:
kissack101
Quote from: Processaurus on January 30, 2010, 08:14:47 AM
Ahhh, yeah - 'panel mounting' is probably the term I was searching for, thanks!
In terms of wiring them, I will only need it to switch from saying 'A' to 'B' so I'm not sure I need much in the way of controls (there will only be one LED switching - the display is more aesthetic than anything else).
Does anyone know a good source for panel mounting displays? Maplins in the UK don't seem to have any, neither does Banzai in Germany and they're usually the ones I use?
Thanks again for your help!
Adam
G. Hoffman
Quote from: JKowalski on January 30, 2010, 06:10:53 PM
Gabriel
Sure, where can I upload the file?
I don't know how useful it would be, though, since a lot depends on your particular parts.  Also, I used a 9 pin SIP resistor network (I had a few laying around - kind of wasteful, but not too bad) to pull down the inputs, which you may or may not have or want to get (it did save a little real estate, though).
It's a really easy project, though, that probably took me all of 10 minutes design time, and I'm sure you could do as quickly.  That way, it fits your particular parts.  I mean, it's one IC, 11 resistors (seven to limit current for the display, and four to pull down the BCD inputs), and the display.  And a header, if you want to use one.  I'm pretty sure you could do it in 5 minutes, as you are probably better than I at designing circuit boards.
(Also, the display I bought has been obsoleted, so unless you already have them laying around, it's probably pretty much completely useless!  I have a few more laying around, so it's still helpful for me, but do you have 0.8" common cathode Knightbright 7-segment display?)
Gabriel
JKowalski
Quote from: G. Hoffman on January 31, 2010, 06:30:45 AM
Gabriel
Gabriel
Yeah, I suppose that's true. And I don't have SIP resistors, though I really need them  :icon_neutral: It's okay, don't worry about it.
cloudscapes
I did it by mounting it on the same PCB I mount my pots on.
{DIY blog}
{www.dronecloud.org}
G. Hoffman
Quote from: cloudscapes on January 31, 2010, 11:44:27 AM
Where are you getting your ribbon cables and the connectors for them?  I'm having a hard time figuring out which ones I actually want.  It's one of those "too many choices" areas for me!
Gabriel
cloudscapes
Quote from: G. Hoffman on January 31, 2010, 05:05:31 PM
Gabriel
I got both the ribbon and the IDC connectors here
http://www.curiousinventor.com/
{DIY blog}
JKowalski
Gabriel
I get mine from an old broken computer  :icon_lol:
