Bipolar power benefits with fuzz?
Started by John Lyons, January 29, 2010, 01:52:13 AM
John Lyons
Ah, ok...I get it.
Here's the switching link you refer to. http://www.geofex.com/circuits/+9_to_-9.htm
Thanks for the run down.
John
Basic Audio Pedals
www.basicaudio.net/
> are you saying that the diodes make the vref point
The two 10K and two diodes have a pretty stable half-voltage at the center.
And I hate extra parts.
In addition to the "sensitivity" trim, we want to set two more points at half-voltage. At A1 it is just a JFET, negligible load. At A2 we have boosted gitar leaked through a 100K resistor. The two 10K will absorb that sorta OK, but there's some positive feedback to A1 which makes gain a bit screwy. To be sure, bypass them well. 10uFd is ample.
R.G.'s points about jack-switching are generally right. I've always cringed when I've seen this done. But everybody does it. K.I.S.S., when you can get away with it.
head_spaz
Is it possible that the Tip and Ring connections are reversed on your schematic™©®¥§ψ?
Deception does not exist in real life, it is only a figment of perception.
Gus
#23
http://www.aronnelson.com/gallery/main.php/v/gus/sickbass.GIF.html
Built this years ago a mix of the ultra for the threshold/ gating control.  opamp muff fuzz with added switches. adjusted values for bass or guitar, yes the input caps are that small try it, .0047 and 1 meg for bass.  Adjusted gain at the first stage for bass or guitar.  A BMP tone control with values I like.
Single 9VDC supply and IMO it is a good fuzz.  This circuit is sensitive to the opamp used when the 2nd stage is used open loop.  I like NS LF353s.  I would use fet input opamps if you do not use a 353.
Quote from: PRR on January 30, 2010, 01:00:14 AM
...And I hate extra parts.
As my friend Albert said, "Everything should be as simple as possible - but no simpler."
Gus
I just checked the gallery, only showed 15 views of the sickbass?   Wow I post a gem of a circuit and only 15 views?
John L. did you look at it?
John Lyons
Gus
I was one of those 15!
Sorry for the lack or response.
It looks like a fun one and it answers some
of my questions. Thanks for posting that!
When I can find time I will try it out.
John
Basic Audio Pedals
www.basicaudio.net/
