Phaser JFETs and the Zener Diode
Started by Bucksears, February 04, 2010, 04:43:31 PM
Bucksears
I was reading in some instructions for the Tonepad Phase 90 that the value of the Zener diode depends on the transistors used.
How is this determined?
Also, is there a 'depth' mod for the Tonepad Phase 90 so you can add a depth control?
Thanks,
Buck
Quote from: Bucksears on February 04, 2010, 04:43:31 PM
Bear in mind that while the JFETs need a specific bias voltage to be "in the zone", the actual voltage source - the battery - will change over time.  The zener acts as a simple regulator to provide a basic voltage source that will be dependable even as the battery drops to 8.5v, 8v, 7.5v, etc..  The trimmer then divides down that stable voltage source.  While it is easy to imagine the existence of JFETs for which that range of possible bias voltages is inappropriate, it is also easy to imagine that there are many JFETs which only require a tweak of the trimmer to work, because their optimal bias voltage is not that far removed from what isoptimal for the 2N5952.
Bucksears
Thanks Mark - will any Zener diode do, or does it need to be above a certain voltage?
He's right, of course.  The zener is there simply to stabilize the voltage supplying the bias circuit in the face of an everchanging battery voltage.  If you use an external PS, then all those pesky battery-related issues simply vanish.
mac
Check the zener before building. I noticed that some zeners (cheap, chinese, etc) do not provide a steady voltage when a batt goes from 9.5v to 8v.
I had buy lots of zeners until I found one that worked fine. Getting quality parts in my country is a pita.
mac
Bucksears
Hmmm....thanks guys.
I use a BBE SupaCharger for power, so no battery worries. It's going to be a JFET measuring weekend......
Thanks again,
Buck
Bucksears
Bumping this one:
Is there a 'depth' mod for the Tonepad Phase 90 so you can add a depth control?
flintstoned
Check out the build reports on the phase 90 at tonepad. They call it an intensity mod there.
I forgot what I was gonna say here.
