raise min gain on a distortion pedal?
Started by TimWaldvogel, February 18, 2010, 06:19:23 PM
TimWaldvogel
i am curious about how this works. i cant seem to find anything on the web  thats helps...
i am curious how to raise the minimum gain of a distortion effect for instance the dod overdrive 250 or mxr distortion plus. i notcied when i roll back the volume knob it goes to completely clean to major distortion. i think its cause i am using linear taper. but i am curious if you can raise the minimum distortion
YOU KNOW WHAT THEY SAY ABOUT LARGE PEDALBOARDS....
.... I BET YOU WISH YOUR PEDALBOARD WAS AS LARGE AS MINE
dschwartz
make the pot smaller value..if what you want is more distortion when the gain pot is at minimum..
Tubes are overrated!!
http://www.simplifieramp.com
TimWaldvogel
oooook ok i think i get it . like for instance if i want the distortion to go from cleanish to max of the pedal i could use a 1 meg, but if i wanted something to go from mild distortion to the max of the pedal i could use a 100k or even a 50k?
dschwartz
yup, those kind of distortions has its max gain when the pot is at 0 resistance, and the min gain is defined by the max resistance of the pot, so yeah..try different values until you find what you want
zyxwyvu
If you're using a linear taper potentiometer, I would keep the pot, and add a parallel resistor. You'll not only increase the minimum gain, you'll improve the feel of the control. The gain control on those pedals is inherently reverse-log, and the parallel resistor with the potentiometer will get you closer to that.
TimWaldvogel
so from the wire that leads to lug 3 on the linear taper pot i should just put a resisitor there? any recommended values?
TimWaldvogel
im sorry you said parallel so like from the two connect lugs on the linear taper?
I would strongly recommend reading the back issues of DEVICE posted here: http://hammer.ampage.org/?cmd=lt&xid=&fid=&ex=&pg=11  and here: http://hammer.ampage.org/?cmd=lt&xid=&fid=&ex=&pg=12
That should explain what you need to know.
zyxwyvu
Quote from: TimWaldvogel on February 18, 2010, 11:35:09 PM
Yes, if I understand you correctly. The resistor should go across the two lugs of the pot that are connected to the circuit.
