Your Favorite audio battery ?
Started by petemoore, February 27, 2010, 01:38:02 PM
  Well, I'm pleased that a dim view of battery use is prevailing here !
  When they're done, they're no fun.
Brymus
#21
I recieved my order from All Electronics yesterday,
On the subject of batteries , I ordered two 9v rechargables $ 5.50 each and the charger that charges two of them at once $2.50 .
So 13.50$ got me two 9V rechargeables and the charger.
My only complaint is that the charger doesnt let you know when they are done,but I kept checking them and they never got hot
(it charges at a rate of 16 ma)
After 3-4 hours I pulled them and they both read 9.97V under load with a battery tester,now 24 hours later they still read 9.49V under load with a tester.
SO I am VERY impressed,IDK if it makes a difference but they are nickle hydride composition,labeled for digital use
My AA rechargeables never gets 1.5V on a fresh charge and someone else mentioned 9v rechargeables only get 7.5 V .
SO these are an obvious good deal for the price and for stompbox use.
I am really glad I spent the extra 8$ on them.
Bryan
PS sorry for lashing out at you PRR glad you didnt take it persoanl and are still helping me with my questions.
oldrocker
I've been using the dollar store Panasonic carbon zinc 9volt batteries.  They're cheap and last almost as long as some alkalines I was using.  Only a buck and sometimes cheaper.  I will one day modify most of my pedals to wallwart p.s. if I ever have time though.
Strategy
This is some solid spec from rechargeables. I'm a devotee, maybe didn't even realize I was losing headroom with them; can you say what brand of batteries and charger these are?
- Strategy
Quote from: Brymus on March 05, 2010, 06:02:41 PM
Bryan
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
Brymus
The name on the batteries is Tenergy,they are light blue with a dark blue stripe at the bottom.
I am very impressed as well I will run one down and recharge it and report back whether it keeps going back up to (+ volts and how long it holds a charge in use.
They still read 9.4 volts (under load) after a day and a half sitting on my shelf.
mikemaddux
Anyone like the danelectro "vintage" batteries?
ever done an a/b test between a danelectro and a duracell?
Completed Builds: A lot...
Strategy
IIRC Jameco may carry these as well, I'll have to check again.
I have  a conventional (consumer) charger; would there be any difference between charger types or battery/charger compatibility issues? I can't think of why there would be but...
- Strategy
Quote from: Brymus on March 06, 2010, 04:15:21 AM
Brymus
The charger is labled Bionicare ,I think that is a brand of home health/medical products IDK for sure.
Here are the two I bought > http://www.allelectronics.com/make-a-store/item/NMH-925/9V-250-MAH-NIMH-RECHARGEABLE-BATTERY/1.html
And the charger > http://www.allelectronics.com/make-a-store/item/BC-92/CHARGER-FOR-9V-NIMH/1.html
I was thinking 4 of these would power a chip amp good enough for a gig w/o using a generator,they are small and light enough and arent supposed to leak...  >http://www.allelectronics.com/make-a-store/item/GC-125/12-VOLT-5-AH-GEL-CEL-BATTERY/-/1.html
By my guesstimates four of them would make a +/- 24V power supply giving enough amps to run an amplifier for about 4 hours.
solderman
A lot of effects mean a lot of power or rather a lot of power feeds. I can actually drive all my effects on one 200mA BOSS wall vart, they don't need more juice but they still need one cord each. But I also need 12V regulated DC to some pedals. I solved this by getting a 12V 1000 mAh DC wall vart and feed this to a regulator to get two 9V and one 12V outlets delivering enough to supply all pedals with. (10-15 but not ON at the same time) I Also remembered that I had a 12V led battery in case I wanted to use battery power (1,3Ah lasts many hours). The thought was to centralize the power feed and to be able to shift between battery and high voltage. This way I can feed a lot of effects on one rechargeable battery or high voltage. The voltmeter is just there to alert me when the battery is running dry.
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
