Add more chugg to a Big Muff
Started by xmugmugmugx, March 02, 2010, 01:33:37 PM
Scruffie
Depends what board it is I suppose... I just removed them on mine, if it doesn't work, add jumpers.
xmugmugmugx
awesome.  Which would you recommend, the first or second set?
- Bob
Solidhex
Don't put jumpers just take the diodes out or interrupt their path. The Jumbo Tonebender (Big Muff style circuit) has no clipping diodes in the second clipping stage so you could try that.
--Brad
xmugmugmugx
ok sounds good, is there a switch i could use to switch between stock diode/LED/bypassed for one of the clipping stages? coincidently what would one use a 4pdt switch for?
- Bob
Tonemonger
If You're up for a complete build then the IC version of the BM is close to what you're after.
If not-then how about a splitter and small mixer and running something chunky in parallel with your muff.
Just a thought !
mnordbye
+1 on changing (mainly reducing) the coupling capacitors, specially the one before the sustain pot.
Also, try bypassing the tonestack.
But the Big Muff in itself isn't very palm-mute friendly, as explained by many posters before me.
Cheers!
General tone addict
Deaf Audio at Facebook
xmugmugmugx
what about adding a individual b/m/t controls?  would more tone shaping help?
- Bob
bumblebee
I have two original big muffs with tone bypass,one transistor, one IC version, neither palmmute any better than any other version.
Tonemonger
Sure I could'nt/would'nt use my IC version for a Pantera type riff or anything like that But, it's definately got a much tighter attack on wound strings than the trans.
azrael
I would try cranking a boost up in front of the BMP. Really adds chunk.
Even an LPB would do wonders. Wire it up in the same box, just slap
it in front.
Richard6
I have actually done an experiment with the BMP. I took at Dist+ and omitted the clipping diodes, turned the gain up, and ran it into the BMP. What is does is filter out the low frequencies, resulting in the chug sound you are looking for. It does create more noise, however.
bumblebee
Sorry,posted in the wrong thread.
