12VDC ECC82 Mitsumin Valve Caster DIY
Started by maaalune, March 15, 2010, 08:01:37 AM
maaalune
This is my DIY Matsumin tiny box.Larger image http://www.foto24.ee/showPhoto.php?photoID=2334202
...and this is short description and overview.Larger image http://www.foto24.ee/showPhoto.php?photoID=2334203
Look at the inside.Larger image http://www.foto24.ee/showPhoto.php?photoID=2334201
Very good PSU from Tracopower to the 12VDC fixed voltage circuit.Very low hum/noise level.Complete PSU image, coming soon.Larger image http://www.foto24.ee/showPhoto.php?photoID=2334204
With Regards,
maaalune
punkin
Very nice build. Where did you find that power supply?
Ernie Ball Music Man - JPM, THD Univalve, Grace Big Daddy, PepperShredder, BSIAB2, FireFly Amplifier.
maaalune
I bought it long time ago from https://www1.elfa.se/elfa/index.jsp,for the another project(High End preamp),but did not want more.
OK.Now found good application.This PSU have excellent signal/noise ratio - but not cheap!
Renegadrian
tubelectron
Congratulations maaalune.
I particulary like the shape and material of the box (what was its "1st life" ? where did you find it ? what are the dimensions ? was it originally drilled ? )
I wonder if you have put that 12VDC PSU in the stompbox or is it external (wall-wart style) ?
I did not tried yet a lo-voltage tube ovd, but only hi-voltage designs - thinking that it doesn't sound as well as hi-voltage tube ovd, relying on some friends trials heard - but I am probably wrong and will dig it personnally.
Does your release tends to sound bluesy-smooth-subtle "vintage amp-like" overdrive, with a nice regular decay and overdrive fading with the note, or is it more "heavy distortion" orientated ?
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
