Need help locating a part on mouser
Started by ghostsauce, April 02, 2010, 09:16:18 AM
ghostsauce
Heya, I'm trying to find something like this on mouser: http://www.pedalpartsplus.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PPP&Product_Code=7514&Category_Code=Pot16
I'm trying to get all the parts I need from the same place to avoid shipping costs.  What pots do you guys use when you build pedals?
theehman
Ron Neely II
fx schematics and repairs
ghostsauce
Thanks :P   The shaft looks really long though, can it be cut to the proper length if the knob won't fit over it?
theehman
It looks long in the drawing, but it's actually only .591" (1/2 inch)
Ron Neely II
ghostsauce
Perfect.  Ok, so the last part I need for the condor cab sim is U1 and U2, both 'standard dual oa', which I assume is Op amp.  But I'm having trouble understanding how to search for it on mouser. I don't know what defines it as standard and searching here or even google can't seem to help me.
theehman
Ron Neely II
ghostsauce
You've been a life-saver.  What would happen if I used the wrong one, just out of curiosity?  Would it not work or would it just change the way it sounds?
theehman
It might work, it might not.  It might change the sound for the better or the worse.  I think the Condor expects you to use a 4558 or 1458.
Ron Neely II
ghostsauce
Alrightey, I'll get both.  I think the 8-pin sockets I have will fit them so i can swap if I need to.
ghostsauce
So...  I can't find a 1k linear pot.  Can I use a 0.5K L pot with a 0.5K resistor in front?   And I have to wonder if that will affect it
ghostsauce
Actually, I did find one.  Apparently I suck at searching because I could swear this wasn't here a minute ago.  >_>
Solidhex
.59 is a little long. its longer than the one pictured in the PPP link. This is the 16mm, 10K audio taper, solder lugs with .33 length shaft used in most pedals.... http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15S1-A10K/?qs=HcpTTNlURoqKdT2%2fL9f05A%3d%3d
  Here's the 1k linear pot, same dimensions...
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B1K/?qs=sGAEpiMZZMtxdMMi52izypa54xBHd143%2fRp3WAELoao%3d
Solidhex
Oh NO! they're backordered for 11 weeks? That sucks.
