What are the parts for a geofex spyder power supply?
Started by tddy934, April 20, 2010, 07:05:50 PM
tddy934
What are the parts for the spyder, the one transformer version?
I'm new to power supply's.
I know it uses:
220Uf Cap
10uf Cap
78l09 Regulator
What transformer do I use?
What kind of fuse?
What's a db01?
Can I change the positive regulator to change the output voltage on one output?
If you're new to power supplies, first go read "Power Supplies Basics" at GEOFEX. The link is on the first page.
Quote from: tddy934 on April 20, 2010, 07:05:50 PM
For the 100ma version:
http://mouser.com/ProductDetail/Xicon/41FG100/?qs=sGAEpiMZZMv4oUrzpPKU3NxRjl0xkAsFxcgO3fixXYo%3d
QuoteWhat kind of fuse?
Use this power entry module. It has a fuse drawer for a 5x20mm fuse, and all you have to do is wire up the line, neutral, and ground out of it.
http://mouser.com/ProductDetail/Schurter/62004325/?qs=sGAEpiMZZMv1TUPJeFpwbl4kiq%2f9392MD0raw%252bzB9AQ%3d
You want a 5x20 **slow blow** fuse with 100ma rating for up to five of the transformers.
QuoteWhat's a db01?
It's an integrated diode bridge:
http://www.mouser.com/ProductDetail/MCC/DB104-BP/?qs=Oupk%2fUD005iFy4CheYEEmA%3d%3d
QuoteCan I change the positive regulator to change the output voltage on one output?
Yes. However, if you go over 9V, you must use a different transformer. Read the Power Supplies Basics for why.
Finally DO NOT try this until you thoroughly understand how to wire the AC power line wiring safely. If you have any doubts on how to do this, get help FIRST. You can create electrocution and fire hazards for yourself and others that may not surface for some time. Don't try it until you know how.
G. Hoffman
Everything R.G. said.  But you can also go with the Weber Transformer WPDLXFMR-2.  You can find it HERE.  You'll need a larger fuse, though, if you are using all eight of the 11V secondaries.
Gabriel
  My weber fit in an old power supply box from computer, nice because it easily was cleared of existing SMPS, the transformer fit nicely, has air cooling [though my PS stays cool it seems] and...the IEC connector is already mounted.
  Commercial boxes that do this are quite reasonable IME, 150 or so ships the accessories/finished tidy PS].
  Floating regulated outputs IMO are worth a try, indespensible for usage, and answer all the PS questions anyone could have before they're asked if bought new/readymade.
  And tend to answer a few of the important questions if built from scratch.
  All the other answers [which there are plenty, when using electromagnetics] can only be realized by reading [re-reading] and comprehending YMMV of course.
  Have the answers to safety questions before beginning a build, what they are is so wide ranging...in this case the IEC, securely mounted in a sturdy case, unplugged, is strongly suggested for any build-work.
Brymus
Ah cool,
I have a few older power supplies from ancient PCs I wasnt sure what to make with em.
I had seen tube pedals made from them and was saving them for that round tuit.
But the pedal supply is an even better idea.
Thanks Pete
and Thanks to RG of course for the design.
fisherbim
are all the parts (capacitors and regulator) values the same if i have 220v mains?
LM386s
Quote from: fisherbim on July 07, 2010, 06:43:38 PM
All except the transformer. The transformer has to have 220 (or 230, or 240Vac ) primary. The secondaries, and the circuit components are the same.
smallbearelec
The transformer that R.G. mentioned is 110 volt only primary. This one:
http://www.smallbearelec.com/Detail.bok?no=339
can be wired for 220 volts. I also have this one:
http://www.smallbearelec.com/Detail.bok?no=732
which has multiple secondaries and could be more convenient to work with.
But you would still need an "entry module" and line cord for for 220 volt service, as well as a lot of local help and advice if you want to stay alive through the build.
Regards
SD
fisherbim
thank you R.G. and Steve!
Quote from: smallbearelec on July 07, 2010, 07:11:25 PM
;D:icon_neutral::icon_eek:
i'm going to talk to some guys first before i build this or ask them to build me one instead.
thanks
fish  :icon_lol:
LM386s
mmckinn
#9
dup
