Built the A/B box from GGG but getting hum- any fixes out there?
Started by jimbob, April 21, 2010, 07:47:43 PM
jimbob
I recently built the A/B box to switch between a high gain amp (Peavey XXX in high gain mode) and A Supro 1624(the Supro being used in the  non gain mode) The problem is I'm getting a noticeable hum from the Peavey. I can understand the nature of the problem but wondered if there was a simple fix. I can build the A/B/Y from GGG and Geo but Id have to order a few parts and all without certainty that the hum problem would be eliminated. Ideas? Fixes?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
joegagan
have you tried a ground lifted cable on one of the amp input leads? sometimes this will break up a ground loop.
Philippe
Paul Marossy
Quote from: joegagan on April 21, 2010, 10:14:40 PM
That's generally the approach I take when presented a situation like this.
jimbob
trixdropd
Quote from: jimbob on April 22, 2010, 01:22:21 PM
I'll give it a try
Thanks all.
I second the fulltone link. This will completely isolate the amps from eachother, while keeping all grounds intact and muting the amp not in use...
Paul Marossy
Quote from: trixdropd on April 22, 2010, 09:59:01 PM
I'll give it a try
Thanks all.
Yeah, I've seen that A/B box before. That will probably work. If not, then one of the ground connections would either need to be broken or isolated somehow.
