DI box and cab sims
Started by euronymous0001, April 24, 2010, 10:32:58 PM
euronymous0001
hi!
i'm wondering as to what is the best signal path?
gtr>fx>di box>cab sim>sound card
or
gtr>fx>di box>sound card>cab sim
thanks!
jkokura
Guitar>FX>Cab Sim>DI BOX>Sound Card
or have the Cab sim happen in the computer could be an option, but usually you'd use a hardware cab sim before DI.
Also, it's good to use a reliable amp emulator/preamp before that cab sim also. Something like an amp emulator from ROG is what I would consider, or a preamp pedal made by any number of manufacturers out there...
jacob
euronymous0001
thanks!
"Guitar>FX>Cab Sim>DI BOX>Sound Card"
the FX would be boogey or bsiab2, are we to consider these two as preamp?
so you're suggesting that i use a preamp as well for clean part? (like prof tweed maybe?)
euronymous0001
Rg505bk
How about using cabinet impulses instead of cab sim?
Like this:
Guitar -> Fx -> (amp + dummy load) -> sound card -> Daw + plugin for impulses such as KeFir.
For impulses I'd recommend the Redwire impulses but there are also a lot of pretty good impulses for free.
jkokura
I have no idea what Cabinet impulses are. Care to explain that one? Sounds interesting.
Jacob
euronymous0001
Quote from: Rg505bk on April 26, 2010, 02:14:26 PM
Like this:
??? ??? ??? ??? ??? :icon_redface:
Rg505bk
Ok, here's a short explanation. I'm not really an expert on impulse responses and convolution, though...
An impulse response is a bit like a sonic fingerprint of the source (guitar cabinet in this case). You could, for example, have an impulse respose of a Marshall 1960 cabinet miced with a SM57. Using this impulse file (wav) with your daw and appropriate plugin you can emulate the sound you'd get if you were running your setup through an actual 1960 cab.
There's a bit more info on the Redwire site:
http://www.redwirez.com/
Ps. I don't want this to sound like a weak attempt at Redwire spam - you can get a ton of good impulses for free, but these are (imho) the best. Besides they are like 8$ a set of 600 impulses...
