Use Lock Washers For Jacks?
Started by Steve Mavronis, May 04, 2010, 01:42:34 PM
Steve Mavronis
I bought some 3/8" lock washers for the jacks in the pedals I'm building. I read someone here saying that would be good for a better ground connection to the inside of the enclosure. Does this make sense to do as standard practice or is it unnecessary to bother?
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
Ronsonic
It's good practice, especially if the jack has a grounded sleeve. It does help keep them from loosening.
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
MikeH
At some point (if not multiple points) the jacks on a pedal come loose.  Using a lock washer, or a serrated washer, will reduce this greatly.  So if you're the sort that hates having to re tighten things, then I'd say it's worth it.
As far as the ground connection goes, I don't think it matters that much more.  In amplifiers it's really important to use locking nuts/washers on chassis-ground connections.  You don't want those coming loose.
petemoore
  If the ground wedge [washer or not] is to be trusted, tighten it, ok, if it stays tight.
  Otherwise run a ground wire to the jack, solder it.
John Lyons
Basic Audio Pedals
www.basicaudio.net/
imbuedblue
ericohman
I hate when the input jack on guitars gets loose too. It's constantly loose on my guitars, I never tighten them properly either, just give the nut a twist with my hand each time before I insert the plug. Should be a tool for tightening it properly without having to open the lid on the back...
INSTAGRAM: http://instagram.com/perkabrod
Scroll past all car stuff to see my vintage amps and stompboxes ;)
Eric // SkellefteƄ, Sweden.
G. Hoffman
Quote from: ericohman on May 05, 2010, 03:38:08 PMShould be a tool for tightening it properly without having to open the lid on the back...
There is.
Jack the Gripper.
Personally, I can't think of any reason not to use a star washer.  They cost me 8 cents a piece (I buy them by the 100), and make things much more reliable.  The time it takes me to fix a loose jack once is worth more than the 8 cents, so why not use it?
Gabriel
DDD
Lock washers - very good stuff.
Too old to rock'n'roll, too young to die
Steve Mavronis
#9
I bought both kinds but which makes a better jack ground connection to the enclosure - 3/8" internal tooth or external tooth lock washers?
I'm thinking internal tooth is better because it grips against both the jack and the enclosure surfaces. The external tooth version only grips against the enclosure side.
John Lyons
Yes, internal tooth is the one you want since it grips both the box and the jack.
I use a nut driver and REALLY clamp them down.
Basic Audio Pedals
www.basicaudio.net/
zombiwoof
You're talking about star washers, right, not the split lock washers?.
Al
Steve Mavronis
Right, not split washers. I only use split washers with the LED bezel since it came with it but I generally don't like them.
