External tap tempo for Superdelay?
Started by Guitartoma, May 11, 2010, 05:09:54 PM
Guitartoma
Has anyone tried it?
Looking inside, the tap switch is a spst switch that is on/off instead of momentary.
My thinking would be to install a dpdt toggle switch to toggle between the switch on the pedal and an external switch.
Why? I am building a loop box and would love to have the tap switch on it.
Anyone have any thoughts on the issue?
All the best!
-Tom
G. Hoffman
I talked to the folks at Empress a few months back when I was thinking of buying one (I didn't :icon_cry:), and they were very helpful.  The Superdelay tap is triggered by edge detecting logic (a change in logic, up or down; instead of just up or just down, which is the way, for instance, my DD-20 works).  You can replace the existing switch with a jack easily enough - hot to tip, ground to sleeve.  The only issue is that, if you want to use the same tap switch for other pedals you will need to come up with a way to give each pedal its required logic.  This should only take a few logic chips, though I don't remember which ones at the moment.
Send them an email.  I found them very helpful.  I'm pretty sure this is also covered on their FAQ.
Gabriel
Guitartoma
It seems that the easy solution is to take out the tap switch and install a 1/4' jack in its place. Then install the switch where I want it. That seems easy enough!
G. Hoffman
