Sweet 16 build report
Started by mhartington, May 16, 2010, 11:48:01 PM
mhartington
So i decided to build a Doug Hammond sweet 16 pedal. I'm using the layouts below
http://i835.photobucket.com/albums/zz276/mhartington/sthart.jpg
im putting in the GGG charge pump to get it to about 17 volts
http://i835.photobucket.com/albums/zz276/mhartington/ggg_ps_cp17_lo-1.jpg
I only have 2 questions.  for the charge pump, could i mount the max1044 ic directly to the board or should i socket it?
And for the sweet 16, can i used a 3pdt switch instead of a dpdt switch. That way i could wire a on/off LED.
I post a video later after to show the build and a demo
WGTP
How do you like the sound?   :icon_cool:
Stomping Out Sparks & Flames
fpaul
You can solder the ic to the board; sockets are nice if you have one though.  Just solder quickly and allow a little time to cool  beween each leg.  You can use a dpdt with led.
Frank
