Power Adapter Polarity Question
Started by ronco05, May 18, 2010, 03:40:45 PM
ronco05
I just built a Tonebender with a positive tipped 9 volt jack.Most power adapters have a negative tip.I am running the Tonebender on the 9 volt battery but I want to run it off my adapter.Right now I am running all my effects on a 1 Spot daisy chain.Can I use the Visual Sound Reverse Polarity Converter for 1 SPOT to power my Tonebender? Thanks.
zombiwoof
If you used a 1/8" positive tip jack and wired it correctly, I believe this is the adapter you want:
http://cgi.ebay.com/C35-1SPOT-ELECTRO-HARMONIX-IBANEZ-BOSS-MXR-DOD-KEELEY-/130392484131?cmd=ViewItem&pt=Guitar_Accessories&hash=item1e5bff6923
This is the one I use with my older DOD, Ross, RAT, and MXR pedals with the positive tip 1/8" jack.
Al
