DEBUGGING HELP COMPRESSION/DIST.
Started by diemilchmann, May 19, 2010, 11:42:39 PM
diemilchmann
Ive built this poretty simple compression about 3 times. I didnt bother with the distortion unit, just been building the first part. Its a CA3080 for the OTA, and 2n3904 NPN transistors. Diodes are 1n914. The only change there is is that instead of a.05 uf cap , i used a .047 uf, thought it was close enough. I dont get any sound thought at the output( where it says compressor on). I DO get sound before Q1, and at the - input of the 3080. No signal on the output of the 3080. The schematic is a little MEH in terms of clarity, sorry about the lack of part numbers and such. I have no clue where to start looking. Yes, the pins on everything are right.
Data sheet for CA3080:     http://www.intersil.com/data/fn/fn475.pdf
Schematic: http://imgur.com/VYFVw.jpg
Sorry for the messiness; thank you people!
oskar
still voltages would be super nice!    ;)
3080 pin 5 voltage?
oskar
On the schematic the negative op-amp input only see a cap. My memory just blanked out completely concerning the ins and outs of the OTA, but I think the inputs needs a DC-path just like any other op-amp. The 1M resistor that passes by (left of the 2k pot) should probably be connected to the - input.
I agree with Oskar. The schematic is wrong.
Oskar's right, the compressor part is a Dynacomp, if you look at the schematic in the link below you'll see what's wrong.
http://www.tonepad.com/getFileInfo.asp?id=9
diemilchmann
Ok, so i connected the 1 M and it seems to be working better today. However, it still makes a really bad crackling noise, fating out when i strum hard. It might just be some weird connections or something, but heres some voltages for SAGs:
batt:9.26v
Q1
C:9.26v
B:8.36v
E:9.2v
Q2
C:9.26v
B:9.09v
E:9.2v
Q3
C:9.2v
B:8.95v
E:9.2v
Q4
C:9.2v
B:8.9v
E:9.21v
Q5
C:9.26v
B:9.15v
E:8.8v
3080
Pin 2:9.04v
Pin 3:9.04v
Pin 5:8.77v
Pin 6:9.09v
Hopefully that helps. And thanks for the schem, it helps.
oskar
Again I must agree with Oskar: when all your readings are "9V" (pretty much: 8.3V to 9.2V), your "zero Volt" (ground) is probably missing.
diemilchmann
Ok, thanks. Youre right>.< theground connection wasnt making very good contact. Everything seems to be working, just need to fiddle. Thanks guys!
Quackzed
diemilchmann
unfortunately, the compression isnt all that noticeable. Like, hardly at all. I checked with the RossDya schem, everything looks fine. Any suggestions on how to boost the compression?
