Hardwire hp or lp on OCD clone
Started by fif_freakboy, June 11, 2010, 02:15:03 AM
fif_freakboy
I decided that I just would rather keep the hp on all the time and do without a switch. Based off the "OVD" overdrive layout where there is three leads off the pcb. Would I be correct just to wire a jumper from A to B and leave C empty? .  Here's the link to the PCB if it helps: http://www.aronnelson.com/gallery/main.php/v/MarkMs-Gallery/album15/album76/OVD+LAYOUT_001.png.html
anchovie
Yes, going by that layout that should give the hotter output.
That layout is different to the schematic I consulted over your earlier question. Your build switches in a series resistor, rather than parallel.
fif_freakboy
Thank you very much anchovie, you're help is saving my dad's father's day present.
