Functional substitue for LM358
Started by theundeadelvis, July 07, 2010, 09:50:15 PM
theundeadelvis
Is there a suitable sub for the Lm358 that I could drop into a Small Clone to test if it is the problem or not?
brett
Hi
try any other dual op amp.  TL072/NE5332/...
Brett Robinson
theundeadelvis
TL022 would probably be preferable.
StephenGiles
Quote from: Mark Hammer on July 08, 2010, 11:41:50 AM
Very true, MXR used this chip in the MXR100 - that I can think of.
When you've looked through as many 2-op-amp LFO diagrams as I have, you quickly realize there are two preferred dual op-amps for that: LM358 and TL022.  You might see a 3403 in there occasionally if it,s a more complex  control-voltage generator, but simple triangle LFO's want a low-current chip to keep the ticking under control.
StephenGiles
#7
Ah, thinking aloud through the heat - 31C this afternoon, didn't the Boss CE3 use TLO22?
Found it, yes it did!
