Will a Crybaby work with DC adapter?
Started by Bubesz, July 10, 2010, 03:22:23 PM
Bubesz
Hi!
I have a Crybaby and I wonder if it works only with an AC adapter, or can I use a DC as well?
  AC'll fry it, 60cycle hum is what AC sounds like anyway.
  DC of correct polarity and voltage, if regulated can be almost as good as a battery for wahs. My CB has a 9vdc jack, I use it.
Bubesz
I found a manual here: http://www.jimdunlop.com/files/1145592348_gcb95_manual.pdf First it says AC, then DC and also the polarity. Ok, I'll use a DC adapter then, thanks!
Paul Marossy
Quote from: Bubesz on July 10, 2010, 04:18:49 PM
What they mean is a "wall wart" that converts AC to 9V DC. Sometimes they are referred to as an "AC adapter".
zombiwoof
Don't most wahs also need an isolated power supply?.  I believe that was so in the past.  I always use a battery in mine (I only have one wah that has a power jack, and I don't really use that one much).
Al
