Etched enclosures
Started by Johnny Lemonhead, July 15, 2010, 10:30:16 PM
stallik
You can just stick on the vinyl and etch away (see my post earlier this page) but your suggestion of using the vinyl as a mask for painting, then etching gives me ideas. Thinking of multiple masks/etches....
Tillinghast
@ Stallik, thanks for your reply, I guess I'll stick with just the ninyl then, seems like less of a hassle. Now the hardest part, creating more designs and picking the best one...
Nice that the spraypaint vinyl stencil thing gave you some ideas. I wanted to use spraypaint because I read it would make a robuster mask than toner, the vinyl just seemed like a good idea to have a stencil that actually stays in place properly...
stallik
You're welcome @tillinghast. If you are stuck for design ideas take a look at deadastronuat's work on this and the previous page. His Batman design is simple, elegant & effective. Nicest looking box I've seen in a long time. Shows what can be done by not over complicating things
@tillinghast : as stallick says, try a basic design first,  even just do a practice (design) on the base plate, and see how that comes out before trying the top...
its all in the preparation when etching.  any questions just ask ok,  theres plenty of people who do great etches on here!! ;) 8)
@stallick: thanks man!. 8)
pakrat
Rob, those are outstanding as usual!
I figured I'd put this up because it's been a while since I posted anything in here. It's an echo base delay in a 1590b enclosure.
snarblinge
I love thrall blue inside, have been trying to get all blue caps, where are you getting yours, I keep getting sent the odd red one.
Stunning etch too btw. And enclosure stuffing. Nice
b.
snarblinge.tumblr.com
pakrat
Thanks snarblinge  :icon_biggrin: The caps came from mouser.
roseblood11
Quote from: pakrat on November 30, 2012, 01:05:47 AM
Wow, great! How did you apply the black color? It looks very clean.
Tillinghast
Made a quick mock-up with some cut out vinyl and a sharpie. Now I'm in doubt about the design, I like it, but something doesn't quite sit right to me, considering making a more "standard" design for it... Any thoughts anyone?
pickdropper
Quote from: deadastronaut on November 28, 2012, 07:49:22 AM
These etches are outstanding.  Very impressed with the layouts and execution.
pickdropper
Amazing that you were able to fit a that in a 1590b.  Great job.
pakrat
Thanks for the kind words guys. The way to do the black and blue is to etch as usual, paint black and sand clean. Then I painted over everything with Tamiya clear blue paint. The tamiya paint is really nice, it takes to sanding very well and seems durable. Only time will tell......
escapeplan
Here's a PT2399 delay I did last weekend. Next time I'm gonna do the sky in light blue. Below are some fuzz boxes I did.
thelonious
thelonious
This was my first etch, and I'm hooked. Many thanks to Slade for his great tutorial. Overall it went pretty well, especially since I tried a reverse etch first. My only problem was that I tried to use the HP premium photo paper sitting unused on my shelf, rather than buying dollar store photo paper. Man, was that a bad idea. Or maybe the iron was too hot. I don't know. When I ironed it, a layer of the HP photo paper melted onto the enclosure and the paper separated when I tried to peel it off. I had to spend 20 minutes soaking it in warm water and carefully rubbing to get the mess off. It screwed up the toner a little, but not catastrophically. Anyway, next time... cheap photo paper and lower iron temp.
It's a Hearthrob Tremolo with a white LED wired to flash at the trem rate.
sidewalk
Quote from: thelonious on December 07, 2012, 09:31:58 PM
*Heartthrob Tremolo*
Wow, this looks incredible. I love the green. Nice job, man.
^ cool, nice first etch man, nice green too. :icon_cool:
pickdropper
Quote from: deadastronaut on December 08, 2012, 04:56:53 AM
This.  Love the green.  Great artwork.  Very nice build.
thelonious
#419
Thanks all!
BTW, could I get away with not using primer next time? Would I just have to find the right kind of paint? You can see the primer showing through a bit in the pics, which is interesting, but not necessarily a better look than straight green against bare metal, you know?
