Etched enclosures
Started by Johnny Lemonhead, July 15, 2010, 10:30:16 PM
Arcane Analog
If you are going to etch by limiting the solution to a small area you can simply use a sponge or a brush. Both work better than a dropper as you can work the etchant into the area and remove the waste material.
ch1naski
You guys are making it sound too easy...:)
Mockingbird wish me luck.
electrosonic
Finally got a couple of free hours this morning and botched two transfers. Got distracted (twice!) and overheated both transfers.  Damn.
Andrew.
kupervaser
ch1naski
Well, that's it. I'm going for it. How do you suggest protecting the sides of the enclosure?
kupervaser
Just paint the enclosure black and after it is dry use the sand paper to clean the top for the toner transfer.
I made a walkthrough here
http://www.newtone-online.nl/forum/index.php/topic,6599.msg50736.html#msg50736
It is in Dutch, but follow the pictures and you will get the idea.
ch1naski
What, you think I can't read Dutch? I was just in Solvang a couple months ago.....;)
Arcane Analog
I cannot believe people use paint to protect the enclosure. Just use masking or painters tape and save youself a pile of work and grief. Why would you want to do all of that extra work?
glops
Quote from: Arcane Analog on March 08, 2013, 08:02:52 PM
Painting is probably easier. At least to me, but I would do both and not paint the top of the enclosure and mask the top off. But usually I let the sides burn, as well. Sometimes I paint the inside of the enclosure or use painters tape.
Arcane Analog
How can painting be easier when you have to spray, dry and then sand it off? With tape ypu put it on and pell it of. Zero wait time and zero sanding.
glops
Yeah, actually I agree with you, especially if youre just masking the sides. Sometimes I paint the inside of the box because I usually let the sides burn so there's always some acid that will burn in the enclosure which I try to avoid. But I think my aversion to tape is that when I dont paint inside the enclosure I use painters tape and it always takes so many strips to seal it off. This would easily be remedied by buying wider tape.
Arcane Analog
I use the green painters tape and it only takes one strip to do the whole side of a 125B. It folds over to protect the inside from splashes or the like as well.
ch1naski
I have lots of tape. Not much paint. Seeing as how i have ferric chloride, I'm rolling with that too. I'll do a practice run on my "rock it before you box it" box. I REALLY need to get some laser toner in my old printer....
+1 on tape...
i use electrical pvc tape around the top edge, then cover with masking tape all around to the base and fold in...
the electrical tape makes a good resist, plus doesn't leave residue and comes off nicely...sod painting the sides , then having to sand it all again...
my prep for boxes.,
sand top only, coarse grade 180, ...iron, nail varnish edges, tape, etch, remove tape, now sand edges 180, then top and sides 400-600 grade,
masking tape sides..spray black(colour) on top..dry, sand top (remove excess paint)  with 'used' 400-600 grade....drill....final buff , clean.... then clearcoat...job done. :)
I usually use stikky-backed plastic, like for covering school books. seeing as I don't have a laser printer, I usually have to cut my mask, through the sticky back, with an exacto knife. what a bastard. and I've got two of them to do now.
kupervaser, pardon my saying, but I like how you've made (such) a crappy finish look (so) good.
" I will say no more "
Mustachio
Well I just tested Etching with Sodium Hydroxide...
I used MG Chemicals Positive Developer which is a pre mix of sodium hydroxide and deionized water. I don't know the ratio. But I figured I would give it a try. It worked well.
I poured a small amount into a paper dixie cup and applied some to the enclosure after I masked it ( I used blue painters tape on the sides and some sharpie marker around the edges.
Turns out that stuff eats through paper pretty fast. about a minute or 2 after I had applied some and left to wash my hands I came back picked up the cup to put it some place safer with my bare hands and the bottom fell out!
Haha lil splash landed on my right hand nothing major I washed it off. About an hour or 2 later my hand was pretty dry,red,burning. And thats after a lot of water rinse. But ill survive nothing to bad. It might have been from using these old Nitrile gloves for the 100th time they are probably dirty inside and out.
Either way here's my results. I think I can do better Im not protecting the larger masked areas with anything extra and the sodium hydroxide sort of leaked into the paper masking tape. So some things learned and I'm still happy with the results.
When it was first done.
I reworked it a little with some sand paper and a buffer
Drilled and mocked up with components. Forgot to drill the led hole when I took these pics. It is drilled now and has a 3mm orange diffused :) .
"Hhhhhhhnnnnnnnnnnnnngggggggg"
Jdansti
Turned out great!
Don't be surprised if you have some tiny holes in your clothing next time you wash them!
FYI- in the future, have some vinegar (acetic acid) on hand to wash your hands if you get some NaOH on you. :)
Arcane Analog
That is a sweet layout/design, Mustachio.
rousejeremy
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
ch1naski
Another beautiful etch. I really like the metal on metal look.
