Etched enclosures
Started by Johnny Lemonhead, July 15, 2010, 10:30:16 PM
Flaconsius
Well, just finished an Overdrive with some Clippin´ Options, and tried to make an Old Style Box Look.
Maik
Wow! How did you do that rusty color?
mistahead
It could be done with any of the metal pigment/oxidizer paint combo's I keep raving about.
Depending on material it could just be electrolysis induced oxidization...
But I suspect its brown paint.
ch1naski
The edges look actually worn away, gritty. Nice
Mockingbird wish me luck.
Flaconsius
I made that in an easier way.
After Etching the Box, I painted it with some kind of Patina called "Betún de Judea". I don´t know what´s the English name for that.
And, after it, for the golden and more brilliant parts, I used another kind of Patina called "Metal en Pasta", that would be something like "Mash Metal" in English.
Anyway, nothing that wouldn´t be found in an Art Store.
Regards.
ch1naski
Quote from: Flaconsius on October 02, 2013, 11:42:25 AM
Regards.
Metal en Pasta.....
I was picturing aluminum rotini ......;)
Maik
thanks for the info.
Have to try it on a tweed pedal
Hexjibber
Quote from: Flaconsius on October 01, 2013, 11:23:55 PM
That looks cool man, will definitely have to give that a try!
Nacho5
Oh yeah! Made in Argentina!!! Grande Flaco!
Pettol
@Flaconsius - cool build. So far from what I am usually doing and I need something new...
@Hexjibber - Amazing etches as always (previous page). Is that done with photo paper?
Quote from: deadastronaut on September 29, 2013, 01:55:33 PM
p.s, its not really an etch...just toner.  ;D
So clean. How do you do that toner transfer?
hi pettol:
same as usual,  sand the box, export image from inkscape as pdf (which seems to retain sharpness) , iron...
i peeled the paper (tesco's 150gsm glossy) off when it was still pretty hot to touch...came off with no residue, and clean tonerless paper...very crisp.
then put under cold water and scrubbed with a toothbrush...though it didn't really need it...that's it...no clear coat.
the peel off when hot method has been 100% reliable. and sharp evey time.
Pettol
Thanks deadastronaut. I've never been successful with photo paper, but with these details I might have better luck. (I user pnp for etching, but it leaves that blueish residue :().
Pettol
Oh yes. I'm shocked every time I have to order them.
Hexjibber
Quote from: Pettol on October 04, 2013, 02:31:07 AM
Thanks man! Yes I use photo paper, this one to be exact;
http://www.amazon.co.uk/dp/B0046Z1658
Very cheap (I get mine from the £1 shop!) and has always produced consistent results. After ironing I wait for it to cool and then peel off, it leaves a whitish residue over the masked areas but you can just apply the acid straight on top, no extra scrubbing/peeling etc required, very easy!
Pettol
@Hexjibber - Thanks. I saw your tutorial and I got exactly those. Now I'm eager to try it.
hex:  try peeling it off while still a little hot...comes off nice and crisp..no residue. ;)
Hexjibber
Quote from: deadastronaut on October 04, 2013, 10:49:26 AM
There's no need to with the paper I use man, you can just apply the acid even though there's a residue, doesn't affect the etch. Might try that for just doing toner transfers like you did on your box though, been thinking about trying it on painted boxes
Pettol
I've tried that but I couldn't get a good transfer without screwing up the paint. Now, someone just wrote about high temp paint (used for car engines) and that seems promising.
