Gristleizer Transistors
Started by tomas1808, July 27, 2010, 02:14:02 PM
tomas1808
Hi,
I ordered two 2N3906 from Futurlec for my Gristleizer (one for the gristle and the other for the charge pump). Instead I got one 2n3906 and a 2N3904. From what I gathered one is NPN and the other PNP.
Are they the same? Does it work as a substitute? Different pinout?
Thanks! ;)
Taylor
No, they are not interchangeable. As you found 2n3906 is PNP, 2n3904 is NPN.
They messed up. I would let them know, just so they know made a mistake. But since the part probably cost a couple of cents it's not worth having them send you a replacement  across the planet.
But, it's been a while since I looked at the Gristleizer, but looking at my schematic, there's no 2n3906 in the charge pump. My board does actually use a 2n3904 to flash the LED. Are you building this on your own or on the PCB I did? Can you post the schem from which you're working?
tomas1808
Taylor
Hmm. Well, you only need the transistor if you're using the input jack to turn off power (if you're using a battery). If you do want to use a battery you'll need to get a 2n3906 or substitute like 2N4250 or 2N4402
tomas1808
Problem solved. I just went to the nearest electronic store and bought a few 2N3906s.
Thanks for the help Taylor :)
